Hello all,
I'd like to welcome myself to this Forum. I own a 2005 TSX 6 Speed that I'm currently in the process of restoring believe it or not. I've always loved this car so here I am fixing er' up while I drive my 2010 Civic LX around.
Currently cars in pieces. Transmission is out.
I downed this car originally cause of an oddly aggressive ticking/ bearing noise that starts after 30 mph/ 50 - 60 kmh. I went through all the steps of inspection: Wheel bearing, Half shaft support bearing, Pilot, Throw out, Input shaft bearing, play in axles, torques on axle nuts, etc. Just before the noise started, 6 months prior I put a Clutch assembly in (210K on original Clutch assembly), and 3 months prior I snapped a half shaft trying to climb my driveway in the winter (bought aftermarket shaft, no noise for 3 months at all, no issues). Moving forward - I ended up grabbing the stethoscope out and isolating it to the Transmission while I had my buddy driving it on stands after 50 kmh. I'm going to add a few pictures as I'm feeling like a rookie with this problem cause I've never seen this before in anything I've worked on and I guess limiting yourself to getting rebuilt transmissions for customers instead of splitting cases and rebuilding it yourself limits your experience - I GET IT.
After all my diagnosing, before I put it on stands, my thought was Carrier Bearing failure or chipped tooth in Final Drive. After pulling it apart, Carrier Bearings appear fine. No chips in teeth except slight pitting on the gear of the spider in Differential. But this caught my eye. Pitting at the base of the counter shaft itself and wear in the oil retainer gasket thingy (clearly I got no correct name to describe this) at the base of the shaft under the case bearing.
Any insight would be amazing. I'm just trying to get this car back on the road so I can have something to enjoy cause its been too many years since I had a car/toy to play with.
Under the counter shaft bearing(bearing at the top), there is wearing like the counter shaft is grooving into the base. Under the oil gasket retainer thing below the bearing, there grooves in the case.
Look at the pitting in the base of the shaft. Would this be what causing the noise? Looking like the roller bearing a locking and the shaft keeps spinning.
Apparently there's a post about CSB walking up and creating a pitch that causes a TON of problems. But it's so uncommon. I'm second owner and really didn't beat this thing.
All gears on main and CS are fine. Syncros, no wear on case or egg shapes bearing housing..
One of the motor mounts were worn, maybe causing a pitch in drive light and pitch carrier bearings.
I thought for the longest time the aftermarket half shaft might be too long or incorrect. There's no c-ring at the transmission side which I found unique (wish I had money for a honda drive shaft but who wants to drop money like what Honda wants)
