1 - 2 of 2 Posts
As far as I can tell Aftermarket springs and shocks use the same part numbers for both the TSX as well as the 4 cyl. Accord (ie KONI's, ProKit etc.). That being the case and considering the TSX weighs in about the same as the 4 cyl. accord coupe do you think the A-spec suspension will work on the Accord?
, Administrator Emeritus
If I'm not wrong, they share the same chassis platform whilst having a different exterior shell and engine. You should be able to fit that without much hassles. Best to check and obtain endorsement from a Honda or Acura dealership where you may be purchasing the A-Spec suspension kit.
1 - 2 of 2 Posts
