So I've had this problem for a while and it is finally bugging me
When I first start my tsx or if i have been driving it for a while it has a hard time going into gear...it grinds in reverse unless I run through the gears for a while it loosens up...when I try and put it in 1st the car moves forward a little bit - almost like clutch drag
This is mostly only startup - as I drive it gets better - my clutch fluid does get a little low so I'm thinking the slave cylinder or master is leaking
Seen correct? Any other ideas?
