Hmmm, if you can that would be great. i am currently thinking about using either UR Pulleys for the RSX base, or some other alternative lightweight set.Yes their the same.
No need. Tell me which pulley you plan to run I will tell you the p/N for the belt to run![]()
that was the next step that i was gonna take after i found out about the same size pulley because i knew someone had a thread like that somewhere here.Here is everything I know about TSX & RSX crank pulleys:
http://www.tsxclub.com/forums/1st-g...-crankshaft-pulley-damper-technical-info.html
