sublime3sixteen said:
Oh and if it's not a 360 Watt Stereo where the hell did they get that number from? And if they just managed to pull it out of there ass, that's false advertisment buddy.
It's 360 PEAK watts @ a high level of distortion.
It is NOT 360 CONTINUOUS (RMS) watts @ a low level of distortion and no-where does Acura claim that it is. People like you just ASSUME that it is because you're not educted enough on the subject to know the difference.
My "Monsoon" stereo was advertised as a "300 watt" stereo. That's also a BS "peak" rating that has little to do with reality. The difference is that I knew that when I bought it.
Acura is using 30 watt max "continuous" speakers in the car...That says it all right there.
REAL stereos are rated per the example below:
100 watts per channel RMS @ .05% THD
That means 100 CLEAN watts (just .05% distortion) per speaker.
Want to LEARN about the OEM TSX stereo:
Go to:
(substitute a "u" for the "*")
http://www.cl*btsx.com/bbs/engine/forum/51.html
Here's a preview:
"Posted by: fcaron
I test drive Acura TSX yesterday April 18th and I am too really dissapointed with the sounds system.
I checked in the TSX trunk and saw the 6x9 brand. These speakers are Pioneer speakers rated max 40W, nominal(RMS) 20W. It's written on the speaker magnet, everybody can see that.
So my guess is that all those speakers are low quality Pioneer stuff. The 360W system that Acura uses is actually made of two 4*45W standard amps found in regular audio dash units.
Then I went road test. I won't comment here on the driving impression (positive) but while testing sound, I made sure to use all the flat ajustements, except for the fader ajustement which I set +1 to the rear seats.
Overall, the sound system is an ok system, but nothing impressive. Not a lot of bass, vibration is early present in doors when you add a bit of bass. I played jazz fusion and Massive Attack. I concluded that this audio system is not the one I anticipated. The RSX Bose system is way better!!!!!
Those of you who don't care about audio quality and presence will be satisfied with the proposed audio system in the TSX. That one is not for me, I will certainly change speakers and add amp if I finally choose the TSX.
Cheers!
Posted by: Splashman24
You have confirmed what I have posted earlier. For a "premium" system it sounds horrible. I have a TSX on order. When it arrives in May, I too will have to make changes. I'm almost 40 so I am not interested in a loud booming system. I want a clean sound with the appropriate low end."
