1 - 20 of 25 Posts
Just purchased a 09' TSX with only 10k miles and factory certified, on my test drive i didn't really test the audio much because the salesman kept talking up the car only to find out when driving it home the right rear speaker is completely blown, how can you have a certified vehicle if you don't even bother to notice the obvious. So i made an appointment to get it fixed and had to bring it in for testing, so i brought it in and the tone deaf shop rep took 5 mins to figure out its blown and order another, then i have to make another appointment to have it installed, now the other back speaker is starting to crackle at lower volumes, tell tale sign of a voice coil going bad!!! what kinda crap is this, I've installed systems that sound better and get louder and cleaner for under $400, the kicker is with the ELS audio sys you cant even upgrade if you want to everything is proprietary, you cant even get a line out signal from the head unit to use your own amp and speakers. Dont get me wrong the ELS sounds great for a factory sys when the speakers work but this is unacceptable for even a econo box Chevy let alone an acura. Any one else had this problem or need to vent please join the discussion.
I too recently purchased a CPO 09' and like you didnt notice the mid range door speaker being flaky :(. Took it back in and they had to order the speaker. One other issue I didnt notice was the outer recesses of the painted grill (could be coated imo) are bubbling and showing the black plastic. Service coordinator said they would replace that as well. Other then that, it is one nice ride and really enjoy it to this point.
Nazzzcar
, Moderator, Performance
well to calm you down lol, you dont NEED pre outs to have a good system, i should really make this a thread because ive said this like 9 times haha. but anyways you use the on board amps as preamps, then each speaker gets its own channel (subs get one) and they each go into your new amp. your setup looks bone stock, kicks harder than most systems and you call it a day:)
just swap out your speakers for JLs or Alpines cause youll pop the stockies really quick if you dont
Discussion Starter #4
I've read that the signal coming from the ELS amp is specifically tuned for the Panasonic speakers it pushes so if you tap into the line going to the sub woofer you will only get the frequency the little 8" factory sub can handle and miss out on a ton of low range, same goes for the mid range speakers witch makes this one hard system to upgrade, wish i knew this when i bought the tech package
Co-Driver
Ya my passenger front speaker is the worst but I think all 6 6.5" speakers are blown. I just got my replacement speakers today and I will try and install tomorrow.
Co-Driver
Finished pulling my speakers 5 out of 6 were blown. Now I just have to make some mounts and do some wiring for the new speakers. I will post pictures as soon as I have time
Same issue here with my 09 TSX CPO i purchased last week. 3 blown speakers and dealership replaced all 3 under warranty. Agreed CPO should mean they spend the extra time to verify equipment is functioning correctly, but at least it was covered.
Co-Driver
Too bad mine was out of warranty. Just finished installing the new speakers yesterday. Even though its a good amount of work, it's worth it in the end. The new speakers sound amazing. I am hoping to have some free time tonight to do a write up.
, Regional Meet Leader, San Diego,CA
I'm way passed my warranty, still replacing speakers because they replaced them like 5 times when under warranty...
I just noticed the front passenger door speaker in my 2009 TSX tech package is blown as well. When I went into the sound settings I noticed it was set towards the driver by the previous owner I would imagine. I purchased the car as a CPO from Crown Acura. I have scheduled an appointment to have the speaker replaced.
I got to start checking my speakers too. But CPO or not, it should still be covered by the manufacturer's warranty correct? Mine is a 2010 with 17K miles.
Had my front passenger speaker fixed at the dealership today. under warranty.
I just got a 09 with tech and I have the same problem the car has 43k miles and I got another warranty when I got the car will they still replace it
Sent from my HTC_Amaze_4G using AutoGuide.Com Free App
The story on the '09 Speakers is that there was a lousy run of them for almost 6 months from the component manufacturer. So they kept blowing, Acura kept replacing them, and then they'd blow again. I had a half dozen of them go. Eventually Honda figured out the culprit and recalled the bad batches from inventory. Suddenly speakers they replaced didn't need to be replaced again. Since it takes a while to have all of them blow and be replaced, and they didn't feel like fessing up that the entire install base was bad, they have a quite policy of just replacing the speakers in '09 Models until the entire set in the car has been replaced with 'good' ones. If you talk to the Regional Service Rep you can get it done out of warranty.
I have an 09 CPO I bought two months ago and I can tell at least the passenger front speaker is blown. Are you saying if I ask the dealership, they'll replace ALL the speakers?
1 - 20 of 25 Posts
