1 - 20 of 21 Posts
my front wheel (19x9.5 +42) is just slightly rubbing onto the caliper. when i went to tony to roll my fenders today, we notice my front is slightly rubbing the caliper causing a grinding sound when i roll. he said since its only slightly touching and that its not completely bad at all, the caliper will just shave down a bit of the wheel so it wont make a sound anymore.
question is, is that enough? right now there's no sound so im guessing its done "grinding", but should i still get spacers to be safe? or there's no problem with it now and just leave it at that?
here's a pic
· ....its fate....
To keep ur mind at ease, why not run a small spacer to give it more clearance?
yeah leaning towards that...trying to find some 3 or 5 mm hubcentric ones with studs
Discussion Starter · #4 ·
Is it safe for me to drive around now?
Discussion Starter · #6 ·
ohhh hmm...i feel like there wont be much studs left if i do 5 mm with no extra studs lol, or im just paranoid.
Discussion Starter · #8 ·
thank you mr. tekneek :thumbsup:
Discussion Starter · #11 ·
awesome, thanks guys. any 3mm spacers you guys recommend? i normally only see 5 lol.
Discussion Starter · #14 ·
thank guys! gonna order them and try it out
Discussion Starter · #16 ·
sadly i do not have a dremel (nor have i ever even used one!) since the spacers are only around 30 bucks, and they are local, so i'll just pick it up and install it today when i lower my front more :D
thanks for all the help though :thumbsup: i freaked out when i found out i was rubbing the caliper LOL
Discussion Starter · #18 ·
forgestar cf10 19x9.5 all around
Discussion Starter · #19 ·
so i i installed the 3mm spacer today, no more grinding!! however...i lose my hubcentric and can't use my hub rings.
question: if i don't feel any vibration or anything without the hub rings, should i just not worry about it? or is it safer/better to have the hubrings or hubcentric spacers?
thanks guys. this is my first set up/modded car so just tryin to do everything right :thumbsup:
· , Chief SuperModerator, Marketplace
IMO hub rings are not a huge deal if you properly bolt on the wheel (i.e. following the star pattern when putting on the lugs, not bolting each lug all the way, etc.). Since they are cheap, I'd say get them whenever possible, but in some situations (spacers) you can't.
I have non hubcentric 10mm project kics adapter spacers on the front of my car and i don't get vibrations and thats good enough for me.
1 - 20 of 21 Posts
