That's a shame.Cyde said:i've had this happen so many times, they will not replace your pads or disk, all they do is just sand and clean the pad's surface, and re-lath/machine your rotors.
wow..datz nice for u..nychousehero said:Interesting post...I just had my front rotors AND brake pads replaced under warranty because the dealer told me that they were warped. My car is new (7K miles) so they informed me that I shouldn't feel any vibration at all when braking. All I should feel are the brakes grabbing. A friend of mine is on his 3rd set of rotors and brake pads (about 60K) on his CL Type-S. I'm thinking that the brake systems Acura uses probably aren't adequate to stand up to the heat of normal braking. I say this because I never beat on my TSX and have never even come to a sudden stop that required the ABS system to kick in. I say that if you have multiple stops that are sudden and severe enough for the ABS to kick in then yes...you might be generating enough heat to get warped rotors.
