So I had a clutch change and I paid a shop to do it. They said they also changed the transmission fluid. I asked them if they used Honda MTF and they said no, they used a different brand.
Being strict on what I want in my car I decided to change it to Honda MTF on my own.
So today I did the job by first removing the fill bolt.
First off, it's good practice to remove the fill bolt first just in case you find out you have a stuck fill bolt AFTER you remove the drain bolt.
Any ways, I removed the fill bolt first and fluids started draining like it was the drain bolt. In my mind I was boggled at how much fluid was flowing out. I'd say a good half quart.
My question is, is this a sign of overfill or is this normal? How does this even happen? Is there another fill hole I'm not aware of?
