1 - 7 of 7 Posts
I am planing to buy a tsx 07 but it sustained some water damage, so the airbag light is on and the power seating dosn't work. The owner said it may be due to the computer module not working correctly, does anyone know how to fix the power seat not working issue and the airbag light issue. Also does anyone know how much it cost to get it fixed thank you.
· True Honda Head
Save yourself some trouble and pass on that. Unless you're getting it for next to nothing it's not worth the hassle. The seats and the airbags are just the beginning probably, run away.
you will need to gut the whole electrical system, switch every harness and electrical part in that car. electrical is real pain in the @$$ to deal with especially if you dont know what youre doing, if you buy new harnesses from honda its going to cost you more than the car is worth at the moment. like angryagent and chikia said, pass on it unless youre getting it for free.
it will be an electrical nightmare.
water and cable do not mix, the pins will start to oxidise and you will get connection problems
my friend brought his ep2 to me yesterday that has some kind of water damge to his front headlight wiring.
he has a disco when he puts his lights on....
1 - 7 of 7 Posts
