1 - 6 of 6 Posts
Car info: 2007 TSX Navi w/130k miles
Recently, my driver side vents started to blow warm/hot air while the passenger side vents are blowing cool/cold air. When i'm traveling on the highway for about 20-25 minutes, the air gets cooler but it doesn't exactly get really cold like the passenger side. So is my compressor going bad, is there a leak in the lines, or something else wrong?
Let me...help you!
You could either be low on refrigerant as mentioned above, or your driver's air mix control motor is faulty. I believe there is an a/c self-diagnostic feature in our cars, but I'd have to look for the instructions for that.
ImHo, refrigerant charge is the last place to check, due to the extremely small charge amount. If it is cooling properly on the passenger side, i would start with the dual climate control system.
1 - 6 of 6 Posts
