1 - 14 of 14 Posts
I have a faint buzzing/chirping when I'm on the gas pedal. It only occurs when I'm on the gas, just the slightest touch and the buzz/chirp is back. It also happens when using the cruise control.
Is it a transmission issue or a drive by wire issue/ throttle body buzz? It shifts fine, recently did a 2x drain and fill with Honda ATF. I've had it for about 3 months, it's an 05 AT with 170k. Does anyone know what this may be?
Discussion Starter #5
The chirp sounds like its coming from the engine bay only when you press the gas pedal. Even the slightest touch and it's there even with the cruise control it is there. I haven't checked if it's there at idle...I'll check.
If it happens while the car is not moving too have someone blip the throttle while you listen for noise under the hood. My first guess is something in the serpentine system. A pulley, bearing, tensioner or the belt itself.
Discussion Starter #7
I was thinking the same about the serpentine system. I changed the belt and I know I have a noisy alternator however the slightest touch of the throttle makes the buzz/chirp return. I'm guessing that the slightest touch of the gas pedal isn't enough to effectively change the speed of the crank and subsequent alternator pulley. There is a negligible change in rpm when you touch the gas pedal which I don't think translates to the alternator. Hopefully you understand my logic (I'm maybe not explaining myself properly).
What I'm trying to say is I already have a whining alternator however the chirp/buzz comes in only when you touch the gas pedal and stops once you get off the gas (no gradual decrease in the noise like you would expect with a pulley as rpm returns to normal)
Keep in mind the pulley ratio from crank to alternator is usually about 3:1... I don't know the exact ratio without looking up diameters of the pulleys. So at idle... Let's say 800 at the crank, that means the alternator is turning 2400rpm or so. A blip of the throttle, say to 1000rpm, would put the alternator up to 3000ish. Given the fact that the condition only exists under load and the belt is new, I would look at idler pulley, tensioner, or maybe even a bearing inside an accessory. Do you have a mechanics stethoscope or long screwdriver to use as one?
Discussion Starter #9
I checked the tensioner pulley when I changed the belt, it didn't have a noise. The pulley on the alternator doesn't spin smooth and there is a whine coming from it (I'll ride it out until I can buy a new one). I just seems that the chirp/buzz is distinct from the whine of an alternator or power steering pump pulley.
Idk....I'll remove the belt and run the engine without the accessories and see if I still get the buzz/chirp. I just hope it's not the transmission. I had an 06 6MT and it had a weird whine in 3rd gear (like a super charger sound) and an Acura tech told me it was the differential bearing going out. So now I have an 05 AT and hope it's not another transmission issue.
I'm not too familiar with auto trans cars but I am very familiar with bearing whine on the MTs. The few autos I have done trans work on, I've never heard what I would call a buzz or chirp.
If turning the alternator by hand is difficult I'd wager that's probably the source of the chirp sound too. Alternator whine is usually from a burnt diode so the alternator is working extra hard to produce the same power, but that shouldn't make it any more difficult to turn by hand. Maybe check your local salvage yards for alternators? A few years ago I got an OEM denso from a similar year Accord for $50. Mileage/longevity is a crapshoot but they usually give you at least 30 days warranty on it. IIRC I got about 40k miles on that unknown milage denso before it died. Was worth it in my case. I replaced it with a rebuilt denso ($225 or so) that has a lifetime warranty.
Discussion Starter #11
Let me rephrase....it's not hard to turn by hand, there is a faint screech or resistance when turned in the direction it spins on the car. In the opposite direction it spins fine. I saw a remanufactured Denso on Rockauto for $179 at my local LKQ it can be pulled for $36. You're giving me hope that's the problem because I don't want it to be the AT.
It would definitely be the first thing I change before looking any further. Cancel out the known before trying to hunt the unknown. A screech means there is debris inside the housing and/or a bearing has gone to crap and it allows the rotating mass to contact the housing.
My 2007 does this while under light acceleration. It started when one of the bolts on my air filter box broke, so I assumed air was leaking somewhere causing the noise
Discussion Starter #14
Did you get it figured out/fixed? However I have it under light or heavy acceleration.
1 - 14 of 14 Posts
