LED Addict
I tried searching but found nothing on the problem i am having. So recently, i have been having this problem where the sound shift from speaker to speaker. What i mean by that is, while playing music, it would randomly play from front left speaker, then it would randomaly cut that off and play from front right. Then it would start playing from rear speakers and so on... I am not sure what the problem is here. Every speaker plays proper sound sometimes but it often does this and its very annoying.
At this point i think its the factory amp or loose speaker connection but i am not sure...
can someone please help me out??
Ps: They are stock speakers and stock amp running on a after market deck. if that matters.
Team Advantage Audio mem
i'd check your conections on the aftermarket unit to the stock amp..
be nice if we knew how you wired up the aftermarket deck to the stock amp too
LED Addict
i'll take a look at it. Actually the deck was hooked up by a local audio shop that are really good. But i will recheck the connections. Any idea on where/how do i access the factory amp?
