I've been searching on the net for new & used TSX 6-speed. Anyway, I've noticed that some engine codes say 2.4L L4 or i4...what's the difference?
Is that what shows whether the car is auto or manuel? If so which one means what?
h1e1l1p
I've never heard of 'L' 4, but the 'I' stands for 'inline', meaning a straight engine where the cylinders are in a single row, as opposed to a V configuration like a V-8. L could stand for 'lateral', meaning the typical front-wheel-drive transverse layout (where the engine is oriented right-to-left instead of front-to-back). I suppose it could also stand for 'longitudinal', meaning the cylinders are in a straight line as well, but that's probably not correct, given the TSX's transverse layout.
Are you sure they're not just calling it a 2.4L 4 cylinder? In that case the 'L' would be for 'litres'.
In any case, the designations you're looking for are '6M', '6MT', or MTX. These are all shorthand for 'manual transmission'.
whatever
Officially it's K24A2
Usually if the engine has an L (like L head 8) it is a flat head engine, with the valves on the side of the cylinders, This type of engine was common in the 50's
