The lower of the two "cubby" holes on the dash of our TSX has a lot of wear on it. Is this normal for these cars? Seems like Acura did not use a very durable material. Is this a remove/sand/paint fix or better to find a panel from a clean part-out car?
i dont think that is possible as it is the panel that flips up when you push on it. right in front of the shifter knob.
Discussion Starter #5
i thought you were talking about thick vinyl similar to a seat cushion! that looks very good, i'll have to figure out what color I should use, probably just use a semi-gloss black sheet.
