1 - 6 of 6 Posts
Hi. I still have stock tire and I wonder which size of wheel will fit well in our
stock tire???
5 x 114.3 +35mm
5 x 100 + 48mm
5 x 114.3 +35mm
Those are all 17 x 7.5. Thank You.
the stock tire will fit any of those... the bolt patter and offset have nothing to do with the tire size that they fit.
Getting those to actually fit on a TSX is a different story, and from the looks of it, none of those will.
5x114.3 is the TSX bolt pattern, but +35 mm offset is way too low for the tsx.
+48 offset would work with the TSX, but 5x100 bolt pattern does not.
so for 5 X 114.3 bolt patter, how much offset is minimum to fit in TSX??? I still confuse about the offset even tho I have reade lots of thread..
Your minimum offset to fit on the TSX will ultimately depend on how low you have your car and your definition of "fit". Don't mean to sound racist, but often times you'll see a lot of cars owned by mexicans with crazy low offsets which means they stick out WAY beyond the bounds of the fender of the car.
Yes technically it works, but does it fit in my book? hardly.
OEM offset is +55. They say the furthest you can really go without having angle your wheels like crazy (aka Camber) is around +42 through +45. Anything lower than that is most likely going to rub with your fender.
Bork Bork Bork
It depends on how wide the wheel is. If you have 7.5" wheels then 35mm offset is fine. The lower the offset the further your tire will stick out.
7.5" with +35mm will sit about flush with the wheel well, it'll work out fine and shouldn't rub.
You have to go 5x114.3
To comment on the previous post. I prefer higher offset as well, but OEM offset is very conservative and wheels can be a lot wider/lower offset than that. The widest offset/wheel combo without modification is 8" with +38mm offset. You might get a little bit of rubbing with that so that's why I recommend going higher than that.
Discussion Starter #6
Thx for replying!!! I may get 17 x 7.5 with 45 off set with my stock tire and since my car is 100% stock, it never lowered yet.
1 - 6 of 6 Posts
