Thinking about replacing wheel studs and I'm wondering if any of you guys tried removing the wheel hub before. I'm getting conflicting info that it's easy to remove the wheel hub vs. it's hard to remove the wheel hub because you have to press the hub out of the bearing, etc.
From what I've read on here, its a pain to swap out studs without taking the hub off, especially in the fronts.
Any advice would be appreciated and I'll hook you up with +rep
