So I was taking my wheels off to plasti dip them, when i was tightening all my bolts, the wheel lock key striped and now i can't take it off, anyone has any suggestions?
I believe you can order a new key using the serial number/identifier number of the set. Of course, you'd be stuck until you get the new lock. If you don't mind destroying your set of locks, then you can use a nut extractor and buy a new set of locks.
go to a tire shop asap. I went to a crappy tire shop once that used a gun on my key and effectively stripped it...I found out after my tire popped on the highway at night far away from home....it was a long night but a 21mm socket did the trick.
