1 - 6 of 6 Posts
I'm booked in on Monday to install my 07 TSX intake cam, injectors, 40 deg VTC On monday and im booked to get the Flashpro installed Next Friday. Will the car still run with out Flashpro being installed and just using stock ecu tune?
I wouldn't drive it until it is able to be tuned. Those mods change the way the engine runs and if you have no way to control it, it will not run correctly.
yea install the flashpro first, if you know how to use the fuel multiplier you can try to pull back the fuel a bit. if you are not sure what you are doing it i'd say to leave it to the tuner before installing. You could cause some damage to your engines/rings if you ie wash out your rings with too much fueling at idle, or lean out if you don't know what you are doing with the fuel multiplier on the flashpro.
1 - 6 of 6 Posts
