1 - 2 of 2 Posts
It should bolt up fine, but you'd be running a 5-speed instead of a 6-speed. Just keep that in mind. It would be a lot less hassle to just buy a manual TSX. It might even be cheaper.
Something I forgot to mention: it should bolt up fine to the engine. Mounting to the car may be an issue.
Custom brackets aren't cheap. You'd be more into it by manual swapping than just buying a manual TSX, anyway. There's a lot more to the swap than just a transmission.
1 - 2 of 2 Posts
