1 - 10 of 10 Posts
Does anyone know if the DC5-R tranny will fit into the tsx. Supposely i heard from my mechanic it should fit.
is it any good ?
Andynolife said:
is it any good ?
I don't know that the DC5R tranny is so good. My point is that the parts are the same on the TSX, so if you wanna do tranny upgrades, you can use parts from the TypeR or Type S even, which have a lot of aftermarket parts available.
, Administrator Emeritus
The DC5-R tranny has different gear ratio's/final drive, and also comes with an LSD :thumbsup:
Discussion Starter #8
Thanks for the reply so basically if i was to get a toda clutch kit with a H.O.P lsd off a rsx they will most likely fit. Maybe i'll give it a try and post later with results.
1 - 10 of 10 Posts
