1 - 3 of 3 Posts
· I </3 NY ROADS
What is the offset? If you are not going more than 2" drop forget 9.5 the front will stick out too much. I'm lowered to no finger gap all around on 9.5 +40. The front cambers on its own once you drop the car. They camber evenly, you just need to correct toe. The rear camber kit you use to correct the camber to your liking and fix Toe.
1 - 3 of 3 Posts
