1 - 2 of 2 Posts
When I bought my tsx the left rear window didnt work. I bought the motor and regulator from acura got it changed but now the only problem is that I cant lower it from the main(driver) switch. I can raise the window just fine from that switch but I just can't lower it from there. what can be the problem? (btw I can lower and raise the window just fine from the switch in the back)
iVTEC no koe
It's probably your master switch on the driver's side. If you live close to another TSX, you can pop it out and test theirs within a couple mins.
1 - 2 of 2 Posts
