I have an 07 tsx.
I am currently having some problems with my driver side wiper blade. It fails to stay flush against the windshield after i start using it or use the quick squirt function.
I know that the wiper blades are the correct size "26 inch on driver side & 16 inch on passenger side.
Could it possibly be a bent wiper arm.
Please help.
Use OEM wipers and replace them with the silicon when needed. It's the cheapest option and the best ones for our car. I found out the hard way by going from the RainX to Teflon to OEM. After switching back to OEM, I found there was barely any noise when wiping and a perfect wipe almost every time.
I really hate those one piece wipers. I feel like they BS when they say it's always a perfect wipe because there's no reinforcement or w/e. Local dealer was give or take $50 for both sides, then if I need to replace the silicon, it's like $5.
When you were referring to silicon, are you talking about aftermarket replacement inserts? The original inserts should be rubber
Plus, 06+ have different oem blades as 04-05. 06+ have the single beam low profile.
