1 - 3 of 3 Posts
Hi in my acura tsx 2005 the wiper dos not move and do not do any sound, i check the fuse next to the left leg and the fuse its ok, what should i do?
Thank you.
Thank you.
put a meter on the motor terminals and see if its getting power, if it is than you know its fried. GL becareful dont short out anything!
What to put here...
To elaborate/continue on tottenham's post, if you determine the motor is NOT getting power, check the fuse panel by removing the fuse and seeing if switching the wipers "ON" will register any power at the fuse panel terminals. If none there, check your wiper switch / combination stalk unit. If there is power at the fuse but not at the wiper motor, you likely have a bad connection at the wiper motor, or a broken or corroded wire between the fuse panel and the wiper motor.
1 - 3 of 3 Posts
