Recently I replaced my read rotors and brakes. Someone notice my two rear tires are wobbly. I took a gander and to my surprise I was scared to death at the condition of the wobble. What could I have done to cause this wobbly on both rear wheels? What should I look for to resolve this?
Car : 2007 Acura TSX
Thanks
Did you forget to tighten the lug nuts, or not tighten them enough?
Also there should be a large nut that holds the rear hub on... you would not normally need to touch that to replace the rotors but if that was loose it would cause wheel wobble too.
Loose lugs, a disconnected toe arm, loose hub, could be many things. Make sure everything is connected and tight. If you still have wobble it may be the wheel bearings. If the bearings are bad thou you would hesr and feel it, significantly, while driving.
Jack it up. Recheck everything..
Discussion Starter #5
The driver side is the worse. The passenger side has wobble but not as bad. Here are photos of the driver side rear suspension. What are your suggestion(s) with what you think might be failing?
The lug nuts were all tight and nothing was loose in the suspension.
