1 - 2 of 2 Posts
Hi guys , my TSX won’t start no fuel , no supply current, changed already the fuel pump relay tnx
I'm hoping someone can help here as I'm experiencing the same thing.
2008 TSX 6MT - 196,000km
Ran into Battery and Alternator problems, after replacing them both my car won't start. Check Emissions light is on as well as TPMS. I don't hear a hum from the fuel pump when the key is in the on position. All eletrics work fine. The engine cranks but won't turn over as if it's not getting gas. I also replaced the relay today as well.
Any recommended next steps? I'm going to get a volt meter tomorrow and check the pins on the wiring to the pump, and maybe give me a better ear on it itself.
How could I go about supplying direct power to the pump to see if it would fire? Can volt meters provide like 5V out?
1 - 2 of 2 Posts
