Manual Transmission Fluid Change
540 views 2 replies 3 participants last post by  merlinj79
On our 1st Gen manual trans TSX. I can change the manual trans fluid by jacking up the driver's side front left, remove the front tire, lower the car until it's level.
With the driver's side front tire off, you can access the manual trans drain and fill plugs.
With the car level, you can fully drain the manual trans fluid, and properly add the correct amount of fluid.
