2004 tsx transmission issues
248 views 2 replies 3 participants last post by  Donnell
#1 ·
I changed the transmission fluid and my tranny hasn’t been right since. It won’t engage hardly and slips when it does. I flushed it. Changed filter. Now I’m moving on to solenoids. Any ideas
#2 ·
Did you use OEM honda fluid? The correct fluid is very important on these cars.
What did the old fluid look like? Was it really black and nasty? The problem with changing fluid on a tranny that's been neglected is there can be sludge build up, which the new fresh fluid starts to dissolve. Chunks of solid crud can come loose, circulate, and clog things up.
If the old fluid was in poor condition, it might be worth taking it to a shop for a chemical flush. Unfortunately there's no guarantee that will work, but probably worth a try. Otherwise might need a rebuild.
It could be a solenoid valve that's clogged but it could also be internal passages.
