Damaged Radiator Seal
42 views 3 replies 4 participants last post by  merlinj79
#1 ·
Radiator Seal against the cap is disintegrated. Anyone ever run into this and is there a fix?
#3 ·
Yes, I've had experience with a similar issue. The top (it's a one piece that includes the inlet portion) had a crack in it so i took it to a radiator shop. They removed the top, did a chemical clean of the core (OEM) and put a new top on it.
One hundred thousand miles later it's still running strong. Find a good radiator shop and they should be able to fix that for you.
