DIY headlight replacement????
3.5K views 2 replies 3 participants last post by  VorteC
#1 ·
I need to replace my ignitor/inverter on my 04 TSX.
Drivers side headlight has given me several problems over the years and dealership service deptments have caused my most recent problem. The last time I had my inverter/ignitor replaced under warranty they never put the back cover on the headlight assembly and water leaked through shorting out my light. Unfortunately this was 3 years ago and they will not honor faulty work after 2 years/12000 miles.
They quoted me 950 to fix and i talked them down to 800 and walked away to do it myself. Ive used this sites DIY threads many times and am thankful for them, however I cant seem to find the thread I need to take this project on myself.
Does anyone know of a DIY thread for this or does Anyone have experience with this fix??
Its been a while since ive been active on this site, good to be back. Thanks in advance for any and all advice.
#2 ·
Do you want to replacew your headlight, or do you want to re-seal it?
There's a big difference in cost and work involved.
Run some searches -- if you're looking to re-seal the lights, lcrazyaznl posted a good DIY a year or so ago. There are also instructions for removing the headlight assembly itself posted in the FAQ/DIYs forum.
#3 ·
Removing/replacing headlight is pretty straight forward.
I'm sure there are a few DIY's on here, just do a search.
But off the top of my head,
remove rad cover
remove bumper
unplug the cables powering headlight bulbs
unscrew the headlight screws
remove the headlight
