ALL warning lights are on. Temp gauge needle bounces all around. Tach needle bounces all around. Speedometer and fuel gauges are fine. Past work - Cylinder #1 ignition coil replaced about 1 1/2 years ago. A/C compressor replaced about 2 years ago. Problems - A/C doesn't work, but that could just be the crap aftermarket compressor that the dealer put in and charged me a small fortune for it. Courtesy lights on rear doors don't work, but I don't remember when they ever did. When I turn the headlight switch to "ON" (instead of "auto", the radio lighting goes away, but the radio still works. Car seem to run OK and all safety features work (headlights, blinkers, stoplights, etc). It does seem to get poor gas mileage. I have no faith in the dealer that is nearby, from past experience. IOW... this could be a fuse and the dealer would tell me it's the ECM. Took it to an independent mechanic. They spent 45 minutes running their diagnostics and said that it needs a "full" diagnostic, which is beyond their abilities. Any help or suggestions would be gratefully appreciated.
